Remote mounted turbo system
I fail to see how that is easier to install than a traditional turbo designed for a certain car. You need to first find a spot UNDER the car to mount the system, then you need to run a fat pipe all the way up the length of the car back into the engine bay??? Last time I checked, this would not be easy on most cars, especially considering most cars have less free space under the chassis than they do in the engine bay.
Did you check this article out?
Here it is on an Evo... doesn't look that bad.
Interesting.
I'd want a heavy duty skid plate under the turbo/intake though.
so you have 6ft of 3" tubing going each direction?
ill keep my turbo on the side of the engine, thanks.
Originally posted by: bR
I've never even thought of it... the turbo housing getting dinged by something will keep me awake at night.
What I was thinking was more of a belt or shaft driven system to move the turbine wheel away from the compressor wheel so you'd have less components (and intake air) affected by exhaust heat.
You mean a Supercharger?
Negative.
no, the intake itself is behind the rear axle. only one piece of tubing.
They offer a kit like that for the GTO. I personally don't see the benefit unless they re-engineer the site to properly protect it from the road.
My friend has a kit on his 04 GTO where the turbo is mounted where the muffler is in the back of the car. Its pretty neat. Theres no where to put a muffler though so its fairly loud.
seems like a relatively smart idea, and on a truck or solid axle vehicle, perhaps not that complicated, but on a small compact car, that extra pipe could present some problems w/ mounting🙂
I can't load the page.
EDIT: Now I can, but I can't find any pictures. Oh well.
I don't think it's a very good idea, because the exhaust gases lose a lot of heat before reaching the turbine.
