Remote desktop software that supports sound?
TwoMix
573
Does anyone know of any remote desktop software other than VNC and PC Anywhere that supports sound? Neither of those 2 do. Thanks.
vi edit
62,484
8,345
"In the previous configuration, the thin clients emulate a Microsoft protocol called RDP. RDP allows users to support a remote screen on a local device. RDP has different versions. RDP 4.0 allows for 8-bit color and does not support local sound. RDP 5.2 allows 24-bit color and support for local sound. RDP 5.2 is only available for Microsoft XP or above. "
from here
TwoMix
573
We need it to test some equipment...i dunno y..but the top people want it.
We only have 2k on these machines, I've looked thru download.com but nohting says it specifically.
arod
4,236
I know 2k advanced server can support Remote Desktop (you have to enable Terminal Services and install something extra, dont remember off hand what it was but its on the windows CD that doesnt come installed defaultly). Id look it up for you but I dont run 2k anymore.
