Remote Desktop Problem
49erinnc
2,095
I haven't tinkered with any settings or anything which may have screwed something up. However (and totally out of the blue), when I try to use "Remote Desktop" on my laptop to connect to my desktop, I'm getting the following message:
The client could not connect. You are already connected to the console of this computer. A new console session cannot be established.
Never got that before and I'm not already connected to the desktop via the Remote Desktop utility. I get this error when I click on "Connect" in the Remote Desktop Connection box (the one that displays the IP address.
Any ideas? My wireless connection is strong and I have no problem getting online with the laptop. Just can't use Remote Desktop like I normally do because of this issue.
TonyRic
1,972
are you logged into the desktop at the local keyboard? If I remember correctly XP will only support one connection including the keyboard.
49erinnc
2,095
Pardon my ignorance but can you clarify? I logged off my host/desktop and was just on the XP log in screen but still cannot connect on my lappy. Prior to getting that error message, I could have all sorts of applications running on my desktop while logged in and still connect to it from the laptop without a problem.
ivwshane
33,363
16,741
Yeah but the remote session should kick off the local user and take over the session.
Try stopping and starting the terminal service.
start-->run-->type in services.msc locate terminal services and stop it and then start it again.
nweaver
6,813
I would support a reboot of the desktop or restarting TS, sounds like something took a dive.
imported_Phil
9,837
Try this:
Start -> Run ->
mstsc /v:<name or IP address>
Specifying /console will connect you to the console session, leaving it off will lock the console session and allow you in.
Worth a try before you start reloading stuff.
