I'm trying to use Remote Desktop Connection to connect to my home PC from work, but I'm having some problems.
I know, by default, that Remote Desktop Connection needs to use ports 3389 and port 80. I first tried setting the port to something other than 80, but I couldn't even use the Remote Desktop Web Connection to get the the first "Connect" screen.
Then, I changed back to the default of 80. I was able to get the first "Connect" screen, but I get the standard error of "VBScript: Remote Desktop Disconnected The client could not connect to the remote computer. Remote connections might not be enabled or the computer might be too busy to accept new connections. It is also possible that network problems are preventing your connection. Please try connecting later. If the problem continues to occur, contact your administrator. "
I'm guessing that port 3389 is maybe blocked from work. I tried changing the listening port per MS instructions and I changed it to 8080 (thinking this would be open at work), but I couldn't even get past the "Connect" screen from another PC at home.
What am I missing here? Can I safely tell which ports are allowed from work?
Thanks for any help you can provide!
