Remote control viewer with Auto screen Scroll
Lotheron
Does anyone know of a remote control package preferably VNC based that will autoscroll the remote screen when the mouse is moved to the edges of the screen?
We normally use Radmin, but it's interfering with some Citrix apps because of the Mirror driver that it uses. VNC works fine, but has to be scrolled manually if the remote desktop area is bigger than the local area. We have users that wish to continue having that feature..
If anyone knows of a VNC based package that does this, I would appreciate it!
Are you using 3.4? What problems are you having?
I haven't noticed any issues with our Citrix apps although I have seen some workstations have issues in general
Yep 3.4.
When using remote control apps with Mirror drivers (both radmin and Dameware in mirror mode does this) the screen flashes rapidly. My theory is that radmin is requesting a screen update, which in turn requests an update with citrix and then it cycles rapidly. It's basically unusable.
Did you try Tight VNC or UltraVNC ? I prefer them much better than the "original" VNC maybe they have the feature you need:
http://www.tightvnc.com/ and http://www.uvnc.com/
Yep 3.4.
