remote control switch?
Status
Not open for further replies.
dabuddha
I'm not sure what to search for. What I want to do is wire a remote control to my light switch in my basement. This way I can turn the lights on after watching a movie without having to stumble around for it. I want some sort of IR receiver that I can wire to the switch but I'm not sure what to use for my search.
TIA!
You can buy one at Home Depot and program a universal remote to turn it on and off:
http://www.homedepot.com/webapp/wcs...H=REC-_-product-1-_-100652556-_-100659479-_-N
This looks like it might do the trick. Now to make things more difficult, the current switch that's in place is a 3 way (?) switch. Meaning there are 2 separate switches that control these lights in my basement so they basically act as a toggle. Hopefully this should do the trick still?
Remote control toggle switches can be found. Some?Most?All? will require a neutral wire to the switch box. If your box has the neutral already your set. If not ...
Status
