Remote control for Creative Labs PC-DVD???
themaestro72
Does anyone know of a remote control package that will work with a Creative Labs PC-DVD with Dxr3 card? The remotes i have found -- including the MouseRemote from x10 -- doesn't support it. Any recommendations would be greatly appreciated.
Workin'
5,309
The Mouse Remote from X10 works with any piece of software out there - if you use maX10 software instead of the software that comes with the remote. You can program the remote's buttons to do just about anything using this software. It's freeware, give it a try, I think it will do what you want it to do. Be sure to connect the Mouse Remote as instructed by maX10, not the way the instruction sheet says.
themaestro72
Hm, the maX10 link above doesn't seem to work. i'll try it again later. did find another alternative call Remote Selector. thanks for the input.
Workin'
5,309
I fixed the link, it should work now. The X10 Mouse Remote used with the maX10 software is better than any other PC/remote control product out there, in my opinion.
I like mine so much I bought a second Mouse Remote to use in case I wear out the first one I got.
