remote connection to 'the fleet'
IBhacknU
Can you ping our corporate VPN server???
12.108.244.240
I can get it from our external network (public internet) at work.... everything works fine.
Here at home on DSL, it's no-go.
I can't ping it:
D:\>ping 12.108.244.240
Pinging 12.108.244.240 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Reply from 12.108.244.254: Destination host unreacha
Ping statistics for 12.108.244.240:
Packets: Sent = 4, Received = 1, Lost = 3 (75% l
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Looks like 12.108.244.254 isn't able to route the traffic to the VPN server. Is this a router that might be having some issues?
Good luck!
I can ping it:
Reply from 12.108.244.240: bytes=32 time=160ms TTL=233
Reply from 12.108.244.240: bytes=32 time=150ms TTL=233
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Minimum = 150ms, Maximum = 160ms, Average = 155ms
C:\Documents and Settings\Garry Mitchell>ping 12.108.244.240
Reply from 12.108.244.240: bytes=32 time=439ms TTL=233
Reply from 12.108.244.240: bytes=32 time=428ms TTL=233
Reply from 12.108.244.240: bytes=32 time=255ms TTL=233
Reply from 12.108.244.240: bytes=32 time=172ms TTL=233
Minimum = 172ms, Maximum = 439ms, Average = 323ms
C:\Documents and Settings\Garry Mitchell>tracert 12.108.244.240
Tracing route to 12.108.244.240 over a maximum of 30 hops
1 9 ms 9 ms 9 ms 172.20.95.254
2 10 ms 8 ms 10 ms rdg-cam1-a-fa00.inet.ntl.com [213.105.91.49]
3 12 ms 13 ms 14 ms bre-t2core-a-pos49.inet.ntl.com [62.253.64.165]
4 13 ms 15 ms 12 ms bre-bb-a-so-330-0.inet.ntl.com [62.253.185.57]
5 15 ms 13 ms 13 ms gfd-bb-b-so-700-0.inet.ntl.com [213.105.172.150]
6 13 ms 13 ms 16 ms gfd-bb-a-ge-020-0.inet.ntl.com [213.105.172.197]
7 16 ms 15 ms 15 ms pos4-0.mpr2.lhr1.uk.mfnx.net [208.185.188.29]
8 17 ms 14 ms 15 ms pos0-0.mpr1.lhr1.uk.mfnx.net [208.185.156.13]
9 84 ms 84 ms 85 ms so-6-2-0.cr1.lga1.us.mfnx.net [216.200.254.77]
10 84 ms 86 ms 87 ms pos0-0.pr1.lga1.us.mfnx.net [208.185.0.238]
11 84 ms 84 ms 84 ms att-above-oc12.lga1.att.net [64.125.12.22]
12 86 ms 86 ms 85 ms tbr1-p012402.n54ny.ip.att.net [12.122.11.213]
13 88 ms 99 ms 109 ms 12.122.11.233
14 87 ms 85 ms 90 ms gbr1-p10.wswdc.ip.att.net [12.122.11.162]
15 87 ms 87 ms 88 ms ar5-a300s1.wswdc.ip.att.net [12.123.8.121]
16 139 ms 139 ms 138 ms 12.119.77.86
17 140 ms 139 ms 139 ms 12.108.244.254
18 141 ms 142 ms 143 ms 12.108.244.240
19 287 ms 210 ms 489 ms 12.108.244.240
20 270 ms 386 ms 704 ms 12.108.244.240
21 471 ms 600 ms * 12.108.244.240
22 251 ms 363 ms 399 ms 12.108.244.240
23 401 ms 391 ms 387 ms 12.108.244.240
Trace complete.
Fine from here
Confused
The first results were from my work Internet connection.
Here at home, I am still unable to ping 10.108.244.240
Request timed out.
Request timed out.
Request timed out.
Reply from 12.108.244.254: Destination host unreachable.
Packets: Sent = 4, Received = 1, Lost = 3 (75% loss),
Looks like a router problem with only certain segments of the Internet having issues.
Strange....
Thank you....
just trying to figure out why some people can reach the VPN server and why others can't ???
