- Jun 30, 2004
- 16,378
- 1,911
- 126
This thread continues my exploratory discussion on AC compressors, "noises" and related matters .
As I said in that thread, I got my stethoscope out to find the source of a low-level cyclic clatter that would come and go at engine idle.
It wasn't the AC compressor. I don't think it likely it's some heatshield or other peripheral source of little consequence. For a few hours, I was worried it might be the waterpump or engine bearings. The stethoscope alleviated my worry about that.
I can't get my stethoscope on the alternator too easily, but I'll find a way. I can see a place I can insert it CAREFULLY (so the engine doesn't yank off my earlobes).
The original OEM alternator went south 30,000 miles ago. That means that the OEM original had been serviceable for 160,000 miles. My mechanic replaced it with an aftermarket or reman alternator, which went bad in six months and had to be replaced again under his warranty.
So far, things seem to be holding up. The noise isn't getting worse. But my experience with reman or aftermarket alternators in the past has left me with a profound bias. One time, I replaced the alternator myself on my Honda -- twice over a year with these rebuilds or aftermarket units. At that time, you would buy these replacements for at most $90. The original Honda part cost north of $200. As opposed to the others, it never failed.
Now, once again or as I mentioned per the OEM AC compressor, I find I can get the original OEM unit from the Isuzu Missouri parts depot for about $600. And also again, that's a hefty piece of change. I don't think the existing unit is ready to die right away, but I also incline to staving off disaster before it happens. I'll put my newly-acquired battery and charging tester on it soon.
Available reman options include an AC Delco unit for about $160 bucks. There are other brands below or around that price. My guess is that these units will be available for a long time into the future.
But I'm still wavering between acquiring the OEM unit and a reman. And the OEM is a "hefty piece of change". Any insights here? If I got 30,000 miles out of the reman unit that was installed in 2009, I could go just as far with another reman unit.
Doing the work myself would still be a PITA for a guy my age -- or maybe I'm just lazy -- but I'll have to put my SUV up on jackstands so I can get at that sucker. If I let the natural disaster occur whenever it happens, I could just have the repair shop order their choice of part and charge me maybe $500. But I worry that more damage could occur than just a broken fan belt if it seizes up. Doing it myself means an outlay of $600 for the OEM, less than $200 for the reman ACDelco. I'm pretty sure my mechanic could do the work without any worry of getting a bad part he couldn't return and replace, if I were to present him with the OEM unit.
So . . . . what about ACDelco reman alternators? Who knows?
