What Flash card formats do you need to be able to read? I have an unused YE Data 8V07 ver.2 combination floppy drive/flash card reader for sale, but it can read just the more common ones: SD, compact flash, multimedia card, Memory Stick/Pro, Smart Media, microdrive. I've updated it to the latest firmware so it may read a few more types but I haven't been able to find out for sure. Here is the
specs page for the latest version - this one may read all those formats or just the basic seven. It can hook to either a standard 0.1" spaced pin header (4 or 5-pin - only 4 of the pins are actually used anyway) or a standard USB socket. These are much better than the similar Mitsumi units. PM me if interested. It has a beige bezel, but can easily be painted or dyed black - I can do that for a small charge.
This is the
support page so you can see the physical difference between the models. The only real difference I can tell btween the ver.2 and ver.3 units is the layout of the card slots.
.bh.
