relatively small and powerful laptop for +-$1000
booth_1
Hi all,
I am looking to get a laptop in the next couple days (from the US), my last lappy fried after playing bioshock but until that point did alright with 2 year old medium specs.
I will use it a lot for games and digital work, but I don't need to run games at crazy settings or high resolutions, but I would be able to play things like AC 4 or BF 4 without slow down (or frying the laptop). I am a traveller so it would be nice if it was somewhat portable.
I am thinking between 13" and 14" for screen size, and a profile of around 1 inch. I could be persuaded to up my budget and possibly size, but would prefer to be as close to the lighter slimmer build as possible.
i liked the look of this though it is a bit out of my budget and I have heard a few bad things GIGABYTE P34G-CF1 Intel Core i7 4700HQ(2.40GHz) 8GB Memory 1TB HDD 128GB SSD 14.0" Notebook
Also this seemed alright but maybe a bit bulky and heard bad screen and bad battery Lenovo IdeaPad Y410p
So anyone got any ideas? Even if they are less powerful and more mobile, or less mobile and more powerful. I am just basically looking for something to buy before my visitor from the states leaves (I am in mexico).
Appreciate the help.
Cheers
Tyrhone
At that price (or any price, really) you're going to have to make a compromise. There are small laptops with a nice screen in that range (Yoga 2 Pro, for example), but you're not going to play shooters on them. There are big, heavy gaming monsters that are like mini desktops both in performance and size (the Y410p).
Some options for you -
Acer V7 482pg i5 version
Clevo W230ST (small and light but just not slim)
Clevo W740SU
It depends on your expectations though. Games like BF4 are quite a demanding game, if you want it to be smooth at max settings then forget it at your budget.
Thanks guys for the advice. Just thought I would let you know I went for the gigabyte p34g at $1400 ( my missus said I could spend more cause its christmas). I'll have it in 4 days and cant wait!
a small and powerful laptop would be haswell based 11 inches Macbook Air for less than 1000.00!
I would look at best buy they sell great laptops. Also you could check out acer aspire series they run very well.
HP Spectre 13t-3000 Touchscreen Ultrabook: i5 4200U, 13.3" LCD (2560x1440), 4GB DDR3, 128GB SSD, Win 8 $856 + Free shipping
13t-3000 Touchscreen Ultrabook for $1071 - 20% with coupon code PC92229 = $856 + free shipping
Click customize & buy
Upgrade to "13.3-inch diagonal Vivid QHD Infinity LED-backlit Display (2560x1440) Touchscreen" + $70
Proceed to check out and enter coupon code PC92229
Final price $856 + free shipping
Specs:
i5-4200U CPU
4GB Memory
13.3" Touchscreen LCD (2560x1440)
128GB SSD
Intel HD Graphics
2x USB 3.0, 1x HDMI, 1x Mini DP
WiFi N + Bluetooth
Backlit Keyboard
4 Cell Battery (up to 9 hours)
Windows 8
Awesome for the price. I would recommend going with 8GB of Ram though.
http://www.shopping.hp.com/en_US/hom...k-ENERGY-STAR-
This is from slickdeals but i didn't want to directly link to them.
