When reinstalling XP Pro do I have to change the order of the boot device back to cdrom 1st or can I leave it as floppy 1st hard drive 2nd and cdrom 3rd?
If you want to boot from the cdrom, it has to be the first in the boot order.
Otherwise it will try to boot from the hard drive, even if there is no OS installed.
