randomlinh
my main drive is 80GB, the secondary is 40GB. the 40GB is close to full, and the main drive has 20GB or so of media that i wont' want deleted.... but i want a fresh install of xp w/ no reference to users/files/registry/etc from the old install (say, i upgrade mobo, just want to do a fresh install).
question is, what would be the best way of doing this? Don't really want to install in another directory.. even so, i think xp will find the old version and pull stuff over. can you run from the command prompt and delete the windows directory (the emergency recovery console rather.. the one you can access from the xp boot cd)???
Appriciate any thought on this. Other than the obvious of finding a backup solution and copy back. I'd like to avoid that if at all possible.
Linh
Linh
