Reinstalled XP with Sp1, and sound card wont work
svtour1
i updated my windows xp with sp1, and now my Hercules Gamesurround fortissimo 2 wont work. It recognizes it as a sound card, but i cant get the drivers to work, and i dont have the original cd.
I would suggest you go to the windows update web page and have it scan your computer for updates. It may find newer drivers for your card and install them for you.
Otherwise check the sound card mfg website for XP compatible drivers.
Good Luck
