Reinstalled WinXP Pro
StarLancer
573
I rememeber from way back when that there was a code to type into the Run box that would delete all of the Windows Messenger crap from your pc but i cant seem to find it anywhere. Can anyone point me in the right direction?
CGras90
57
Start -> Control Panel -> Add/remove programs -> click "add/remove windows components" from the left side bar -> Uncheck windows messenger from the bottom of the list
jlbenedict
Banned
Jul 10, 2005
3,724
1. Browse to the \WINDOWS\INF folder
2. Find the file "SYSOC.INF"
3. Look for this line "msmsgs=msgrocm.dll,OcEntry,msmsgs.inf,hide,7"
4. Remove just the "hide" portion of it. Leave the two commas (,) in there. It should look like this: msmsgs=msgrocm.dll,OcEntry,msmsgs.inf,,7
5. Now you should be able to use the Add/Remove Windows components to actually uninstall Messenger from the system.
jlbenedict
Banned
Jul 10, 2005
3,724
This only removes all the shortcuts to messenger.
you have to do the steps I posted above to access the hidden option
benjamat
264
Run this from start menu.
RunDll32 advpack.dll,LaunchINFSection %windir%\INF\msmsgs.inf,BLC.Remove
You will not see messenger after.
