Regular or Premium? Is premium fuel worth the premium price?
C'DaleRider
Guest
Jan 13, 2000
3,048
Excellent article from Car and Driver:
Link to article HERE.
Full article here:
By FRANK MARKUS
November 2001
There's no shortage of opinions on who is to blame for gas-price gouging. One thing that's certain is drivers tend to economize at the pump during extreme price rises?they buy cheaper, lower-octane gas.
In the old preelectronic days, cars would protest such parsimony by pinging like a pachinko parlor, but most modern cars don't complain audibly, so maybe they don't mind. Or do they? And conversely, is there any benefit to be had by springing for the expensive stuff when you're feeling flush?
To find out, we ordered a fleet of test cars?some calibrated to run on regular, others that require premium?and tested them at the track and on a dynamometer.
But before we go into the results, let's go to combustion school. When a spark plug fires, it does not cause an instantaneous explosion of the entire cylinder's charge of fuel and air. The spark actually lights off a small kernel of air-and-fuel mixture near the plug. From there, a flame front expands in every direction, gradually igniting the rest of the air and fuel. This takes some time, as much as 60 degrees of crankshaft rotation.
Meanwhile, the air-and-fuel mixture that the flame front has not yet reached is experiencing huge increases in pressure and temperature. If any part of this air-and-fuel mixture gets heated and squeezed enough, it will explode spontaneously, even before the flame front ignites. This self-ignition is called detonation, or the dreaded "knock."
Now for the chemistry lesson: Oil is a hydrocarbon fuel, meaning the individual molecules contain carbon and hydrogen atoms chained together. Modern gasoline is blended according to various recipes, the active ingredients for which include about 200 different hydrocarbons, each with a spine of between 4 and 12 carbon atoms. One of them, isooctane, consists of 8 carbon and 18 hydrogen atoms (C8H18) and is exceptionally resistant to exploding spontaneously when exposed to the heat and pressure found inside a typical combustion chamber. Another, n-heptane (C7H16) is highly susceptible to such self-ignition.
These two compounds are therefore used to rate the knock resistance of all gasoline blends. A gasoline recipe that resists knock the way a mixture of 87-percent isooctane and 13-percent n-heptane would is rated at 87. Racing fuels with octane ratings over 100 resist self-ignition even better than pure isooctane. The octane ratings for regular-grade fuel range from 85 to 87, midgrades are rated 88 to 90, and 91 and higher is premium.
Mind you, premium fuel does not necessarily pack more energy content than does regular. Rather, it allows more aggressive engine designs and calibrations that can extract more power from each gallon of gasoline.
An engine's tendency to knock is influenced most by its compression ratio, although combustion-chamber design also has a large effect. A higher ratio extracts more power during the expansion stroke, but it also creates higher cylinder pressures and temperatures, which tend to induce knock. In supercharged engines boost pressure behaves the same way. That's why the highest-performance engines require higher-octane fuel.
If you feed such an engine a fuel with insufficient octane, it will knock. Since it is impossible, for now, to change an engine's compression ratio, the only solution is to retard the ignition timing (or reduce boost pressure). Conversely, in some engines designed for regular fuel, you can advance the timing if you burn premium, but whether this will yield additional power varies from engine to engine.
Knock sensors are used in virtually all new GM, Ford, European, and Japanese cars, and most DaimlerChrysler vehicles built today. According to Gottfried Schiller, director of powertrain engineering at Bosch, these block-mounted sensors?one or two of them on most engines and about the size of a quarter?work like tiny seismometers that measure vibration patterns throughout the block to identify knock in any cylinder. Relying on these sensors, the engine controller can keep each cylinder's spark timing advanced right to the hairy edge of knock, providing peak efficiency on any fuel and preventing the damage that knock can do to an engine. But, noted Schiller, only a few vehicles calibrated for regular fuel can advance timing beyond their nominal ideal setting when burning premium.
Older or less sophisticated cars with mechanical distributors do not have the same latitude for timing adjustment as distributorless systems do and therefore may not always be able to correct for insufficient octane or additional octane.
We should note that even cars designed to run on regular fuel might require higher octane as they age. Carbon buildup inside the cylinder can create hot spots that can initiate knock. So can malfunctioning exhaust-gas-recirculation systems that raise cylinder temperatures. Hot temperatures and exceptionally low humidity can increase an engine's octane requirements as well. High altitude reduces the demand for octane.
Got all that? Good. Let's meet the test cars and ponder the results. At the lower-tech end of the scale was a regular-gas-burning 5.9-liter Dodge Ram V-8. This all-iron pushrod engine has a mechanical distributor and no knock sensors, so the computer has no idea what grade of fuel it's burning. A Honda Accord V-6 with VTEC variable valve timing represented the mainstream-family-sedan class, and a 4.6-liter V-8 Mustang stood in as an up-to-date big-torquer. Both of those were designed to run on regular unleaded. Our premium-grade cars included the hard-charging 333-hp, 3.2-liter BMW M3 straight-six boasting individual throttle by wire for each cylinder and enough computing power to run Apollos 11 through 13. A Saab 9-5 gave us a highly pressurized 2.3-liter turbo. For the sake of repeatable track testing, all but the M3 were equipped with automatic transmissions.
We ran all vehicles on both grades of fuel, at a drag strip near our offices and on a Mustang eddy-current dynamometer that was offered to us by the engine-tuning pros at Automotive Performance Engineering in nearby Clinton Township, Michigan. On arrival, all fuel tanks were drained and filled with 87-octane Mobil regular fuel and driven for two days before track and dyno testing. The tanks were drained again and filled with 91-octane Mobil premium and again driven for two days to allow time for the engine controllers to acclimate to the fuel type and tested again. All dyno and track results were weather-corrected.
Our low-tech Ram managed to eke out a few extra dyno ponies on premium fuel, but at the track its performance was virtually identical. The Mustang's knock sensors and EEC-V computer found 2 hp more on the dyno and shaved a more impressive 0.3 second off its quarter-mile time at the track. The Accord took a tiny step backward in power (minus 2.6 percent) and performance (minus 1.5 percent) on premium fuel, a phenomenon for which none of the experts we consulted could offer an explanation except to posit that the results may fall within normal test-to-test variability. This, of course, may also be the case for the gains of similar magnitude realized by the Ram and Mustang.
The results were more dramatic with the test cars that require premium fuel. The turbocharged Saab's sophisticated Trionic engine-control system dialed the power back 9.8 percent on regular gas, and performance dropped 10.1 percent at the track. Burning regular in our BMW M3 diminished track performance by 6.6 percent, but neither the BMW nor the Saab suffered any drivability problems while burning regular unleaded fuel. Unfortunately, the M3's sophisticated electronics made it impossible to test the car on the dyno (see caption at top).
Our tests confirm that for most cars there is no compelling reason to buy more expensive fuel than the factory recommends, as any performance gain realized will surely be far less than the percentage hike in price. Cheapskates burning regular in cars designed to run on premium fuel can expect to trim performance by about the same percent they save at the pump. If the car is sufficiently new and sophisticated, it may not suffer any ill effects, but all such skinflints should be ready to switch back to premium at the first sign of knock or other drivability woes. And finally, if a car calibrated for regular fuel begins to knock on anything less than premium or midgrade, owners should invest in a tuneup, emissions-control-system repair, or detergent additives to solve, rather than bandage, the root problem. Class dismissed.
StageLeft
70,150
Buy the minimum that your car's manual says. Anything more is money in the crapper.
veryape
2,433
No car requires or runs any better with anything higher than a 89 octane. It truly is a waste of your money going any higher than that. Newer cars do require or should I say run better with an 89 rather than an 87 but running the latter will not affect the engine in a negetive way, it will just get slightly less in the way of mileage.
ISAslot
2,889
107
Great article!
<< These two compounds are therefore used to rate the knock resistance of all gasoline blends. A gasoline recipe that resists knock the way a mixture of 87-percent isooctane and 13-percent n-heptane would is rated at 87. Racing fuels with octane ratings over 100 resist self-ignition even better than pure isooctane. The octane ratings for regular-grade fuel range from 85 to 87, midgrades are rated 88 to 90, and 91 and higher is premium. >>
They don't put more isooctane in, but an additive. It's cheaper to do so. They used Tetra ethyl lead back in the day. Now they commonly add MTBE.
<< Mind you, premium fuel does not necessarily pack more energy content than does regular. Rather, it allows more aggressive engine designs and calibrations that can extract more power from each gallon of gasoline. >>
Premium contains less energy per volume, because it has more MTBE. (MTBE has less energy per volume than the regular gasoline.)
LAUST
8,957
<< No car requires or runs any better with anything higher than a 89 octane. It truly is a waste of your money going any higher than that. Newer cars do require or should I say run better with an 89 rather than an 87 but running the latter will not affect the engine in a negetive way, it will just get slightly less in the way of mileage. >>
Well, naturally asperated/standard compression cars don't run different, you run your 89 in a car with Forced Induction/High Compression and your gonna have holes in your pistons
CraigRT
31,440
I run 91-94 octane in my car.. no questions asked!
it never gets below gold grade.
it sounds alot cleaner when idling, revving lower in the RPM's with higher octane gas, don't know about stuff like gas mileage, etc, but i think it also keeps the engine cleaner.. cheaper gas is more likely to cause problems with your fuel system (fuel injectors)
to be on the safe side, i'll gladly spend the extra 3 bucks more(CDN) per fill up on higher octane ...
Jzero
18,834
Also, doesn't higher-octane fuel burn less cleanly and will lead to more build-up of carbon and other gunk in the cylinders?
dman
9,110
All of my cars get Premium. I can tell the difference and feel a difference on ALL of them. That said, all of my cars are recommended to run with premium but will run on regular if needed (timing is reduced).
I don't know if 'peak' horsepower is affected but I can definitely tell a mid-throttle difference between regular unleaded and premium unleaded. In addition the cars idle smoother with premium.
When the prices jump up I usually do a half / half blend myself, 87 and 93 octane averaging close to 90 (I'll err on the high side) for less than the price of the pre-mixed '89' octane. If the prices are really insane I'll run a few tanks of 87 Octane every now and then.
TurboQuattro
168
This is not true, if your car requires premium fuel (91 octane) then it is best to use that fuel. My car requires 91 octane, and it is a modified turbocharged engine...luckily premium fuel here is 93 octane. Since my car runs peak boost spikes of 21PSI on an engine with 9.5 to 1 compression anything less will cause detonation. Or as Laust said....holes in my pistons, I don't want holes in my pistons :)
new99
251
<< I run 91-94 octane in my car.. no questions asked!
agreed.
Zenmervolt
Elite member
Oct 22, 2000
24,514
34
<<No car requires or runs any better with anything higher than a 89 octane.>>
You've never towed anything, have you? My father's Explorer (302ci V8) normally runs on regular unleaded (87 octane), however this is not sufficient when towing. I towed two tons behind the truck through New Hampshire mountains, and I found that knock was avoided only when running 93 octane fuel. Also, my mother's Maxima, while it will adjust to lower octane fuel, is clearly more powerful when running on 93 octane for the reasons mentioned in the article. That said, there's no reason to use 93 octane in a car like my '88 Accord which has always run fine on 87 octane. Basically, unless you are getting spark knock, there is no reason to use higher octane gasoline than the manual calls for. Great article, by the way.
Zenmervolt
bozo1
6,364
<< No car requires or runs any better with anything higher than a 89 octane >>
My turbo requires premium. When I first bought it I forgot and ended up putting 89 in and it ran like shyt.
yakko
25,455
hahahaha!!!! I wish that were true but it is not. My car only runs right on 93 octane.
Static911
4,338
Who here uses Texeco (sp?)?
Man, I'm only getting nearly 250 miles to a 20 gallon tank on my 1993 ls400. With Mobile or Shell, I can get 400-450 miles to a tank. And I am driving very conservatively (no quick acceleration, no going past 65mph on freeway, etc).
static911
ISAslot
2,889
107
<< Who here uses Texeco (sp?)?
static911
Does Texaco run an alcohol blend? If not nationally, maybe locally? If so, this could explain a decrease in mileage.
GasX
29,033
You didn't read the article did you?
Shudder
2,256
What about Sunoco "Economy" 86 octane? You know, just in case I want to save that one cent per gallon instead of getting 87 :)
maxoi1
36
Over here(Sweden) the lowest you can get is 95 octane, my Volvo '81 runs grate.
In US, San Francisco i drove Hynday'89, used regular (89) it run grate.
Morale:
For people who are not interested in cars, just driving them, the differance in octane is as important as
the speed fo a CPU (ex. 1300 or 1333) for people who are nor interested in computers, just using them.
vi edit
62,484
8,344
My 10:1 compression engine doesn't like anything below 90 octane. And it REALLY doesn't like ethanol enchanced gas.
Those germans aren't much for corn I guess :)
Nefrodite
Banned
Feb 15, 2001
7,931
kewl:) all that matters to me is miles per dollar:)
