Registry-setting to start RC5?
KifArU
I´m trying to install RC5 as a service on NT4, sp5. dnetc-install doesn´t work. But I can use regedit. What settings do I put in the registry to start the client and keep it running when the user logs out? (Perhaps somebody has a .reg?)
Thijs
If -install doesn't work, you have bigger problems.🙁 Oh, and I think the location is local machine\software\microsoft\windows\currentversion\run\
Actually its HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\RunServices
where you have a string called distributed.net client with value
"C:\Program Files\RC5\DNETC.exe" -hide
However this applies to win9x only.
On NT4 server SP5 where I used the -install switch, I have the following entries :
REGEDIT4
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\dnetc]
"Type"=dword:00000010
"Start"=dword:00000002
"ErrorControl"=dword:00000001
"ImagePath"=hex(2):22,44,3a,5c,44,61,74,61,5c,44,69,73,74,69,62,75,74,65,64,5c,\
52,43,35,5c,64,6e,65,74,63,2e,65,78,65,22,20,2d,73,76,63,72,75,6e,00
"DisplayName"="distributed.net client"
"DependOnService"=hex(7):54,63,70,69,70,00,00
"DependOnGroup"=hex(7):00
"ObjectName"="LocalSystem"
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\dnetc\Security]
"Security"=hex:01,00,14,80,c0,00,00,00,cc,00,00,00,14,00,00,00,34,00,00,00,02,\
00,20,00,01,00,00,00,02,80,18,00,ff,01,0f,00,01,01,00,00,00,00,00,01,00,00,\
00,00,20,02,00,00,02,00,8c,00,05,00,00,00,00,00,18,00,8d,01,02,00,01,01,00,\
00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,1c,00,fd,01,02,00,01,02,00,00,\
00,00,00,05,20,00,00,00,23,02,00,00,00,00,00,00,00,00,1c,00,ff,01,0f,00,01,\
02,00,00,00,00,00,05,20,00,00,00,20,02,00,00,00,00,00,00,00,00,1c,00,ff,01,\
0f,00,01,02,00,00,00,00,00,05,20,00,00,00,25,02,00,00,00,00,00,00,00,00,18,\
00,fd,01,02,00,01,01,00,00,00,00,00,05,12,00,00,00,25,02,00,00,01,01,00,00,\
00,00,00,05,12,00,00,00,01,01,00,00,00,00,00,05,12,00,00,00
and
REGEDIT4
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\dnetc]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\dnetc\Security]
Check to see if you have the dnetc.com in the distributed.net directory. I've had problems with Windows using the .EXE version if the .COM is there too. If you do, then use the
dnetc.exe -install
there is a space between the dnetc.exe and the -
also make sure you are in the distributed.net directory when you issue the command.
Don't forget to start the service once installed.
[edit]fixed a typo :Q[/EDIT]
