I received a Stop 0x00000051 today and it just keeps coming back. It will occur when the Windows XP logo with the blue bar passes by, then a few seconds afterwards it will appear. I have not modified my hardware in any way. After a few attempts at the normal booting, safe mode, and Last Known good configuration of it not working, I wanted to try the sfc /scannow command. In order to do so, I would have to go into the recovery console. Right after it asks which windows drive I would like to load into, the same BSOD would appear and i'm back at where I started. I have also ran the memtest86 to see if there were any errors there, but it came out okay. So, right now I am unable to load into windows or recovery console, i'm at a total loss. The file system is a NTFS as well.
Does anyone by chance know of a solution to this issue?
Thanks
- hito
Thanks
- hito
