Windows Could Not Start Because the Following File Is Missing or Corrupt: \Winnt\System32\Config\System.ced
I am thoroughly aware that the ced is an unerased part of the previous message.
The problem is described here: http://support.microsoft.com/default.aspx?scid=KB;EN-US;q269075&
The two hardrives are in RAID0, and have been scanned for bad sectors both seperately and in the RAID configuration.
This is occuring a few days after a fresh install. It happend twice already. The solutions in the knowledge base do not work, and fixing it is beyond the ability of the owner of the computer. Even if it werent, having a backup is pointless if it must be used every few days.
The only thing the person installed after it was tested and rebooted many times, is Soundforge XP5. The previous occurance, installing an HP printer's software seemed to trigger the error.
Why does this happen?
How can it be prevented?
Would WindowsXP solve this?
Hardware:
Pentium4 3.0
ABIT P4P800 Deluxe
(2) 512 Corsair 3200 DDR
(2) Western Digital 80GB JB
Matrox Millenium 450 dual head
Audigy 2 Platinum Pro
USR Hardware Modem
Pinacle firewire card
Any help would be appreciated, Thanks a bunch in advance.
Hardware:
Pentium4 3.0
ABIT P4P800 Deluxe
USR Hardware Modem
