Turbonium
Is flash memory inherently more reliable at lower densities? I am only concerned about reliability here (defined as no data corruption within normal operating conditions and within expected lifespan/cycles), not speed.
Say when comparing a 32GB versus a 64GB microSD card of the same make and model.
I realize this is a very general question, and that the answer could vary depending on the type of flash memory in question, as well as other factors. If it helps, assume TLC NAND, and perhaps MLC NAND (given most consumer-level microSD cards use these types of flash memory, as far as I know).
Note: I'm assuming that the capacity of a given card is a function of density, not the physical size of the memory inside the card. If this is incorrect, feel free to clarify.
