Okay, price was right, so I pulled the trigger on an x850xt refurb from Newegg. I have an older Antec Power Supply rated at 380watts... Has SATA power leads built in with the other normal connectors, but this was pre pci-e so no specific connector for that. I purchased one of those cheapy dual 12v to single pci-e power connnectors to power my card.
Current Hardware:
ASRock Dual-SATA939 with AGP and PCI-E slots
AMD x2 3800+
1 80gb SATA WD drive
1 160gb UDMA 133 WD drive
1 DVD Drive
1 CD/DVD Writer
1 gb mem
1 floppy drive
Previose graphics card 9800pro AGP
Everything worked great, no worries...
First attempt: Pull 9800pro, insert x850xt, forgot to add power to x850xt and flip "On" switch= "No Vid" beeps from MB, duh...
Second attempt: add cheapo y-cable standard adapter conversion to pci-e power adapter to x850xt = nothing. Fans don't even flinch, no nothing.
I suspsect that my power supply has met it's match, so next step to see if I'm close:
3rd attempt: unplug power from floppy, both DVD drives, and extra case fans = Same.. Dead, not even a flicker of light or power when power switch turned on...
4th attempt: Pull supplimental power out of x850xt, get the good old "No Vid" beeps. Good, haven't fried anything at least...
5th attempt: pull x850xt, insert 9800pro... = Running again with old, slow vid... At least it's working..
So, do those cheapo y-cable PCI-E adapter thingy's actually work normally? If so, am I just a fool to think my old 380watt power supply is enough to power this thing? Is this thing dead like so many other refurbs from newegg?
If I could get a quick reply I'd appreciate it. Want to make a trip to Fry's at lunch if I need a new PSU...
---------- Updated --------------
- New Enermax FMA 535w purchased and installed... Video card seems happy now.....
- 3dMark06 = 2397
- SM2 = 1178
- N/A = N/A
- CPU = 1863
Muchas gracias....
Current Hardware:
AMD x2 3800+
1 DVD Drive
1 CD/DVD Writer
1 gb mem
1 floppy drive
- 3dMark06 = 2397
- SM2 = 1178
- N/A = N/A
- CPU = 1863
Muchas gracias....
