Hello All ~
I just built a new mahcine:
MSI K8t Master2-FAR
(2) Opteron 244s
(2) 512Mb OCZ PC3200 Registered/ECC RAM
(2) 160GB WD 7200rpm SATA HDs in Raid 0 on the mobo
etc
Since setting up this box, i've been gettting the following message about once a day in a number of different applications:
Application popup: devenv.exe - Application Error : The instruction at "0x4a619262" referenced memory at "0x00000000". The memory could not be "read".
this is my first experiene w/ registered RAM, AMD procs, and RAID setups.... I'd guess that this is my RAM's fault, since the memory can't be read..... but i really dont know. is this hardware? or driver errors?
any ideas? should i RMA my RAM before the chance expires? i should have until the 23rd....
thanks for the ideas... is there a better place to ask this question?
nema.
MSI K8t Master2-FAR
(2) Opteron 244s
etc
nema.
