Scarpozzi
- Jun 13, 2000
- 26,389
- 1,778
- 126
I also agree...you probably have a decent-sized air leak that's making it cold in there.
If you can get an infrared thermometer, shoot it at a few different surfaces in the room and see if you can find cold spots vs say the door itself or something that would be relatively neutral.
More specifically, Check around your windows....your bathroom vent...your shower/bath valves... Think about wall cavities that may be open and allow air to move freely...like where the pipes are. If you have access to these areas via crawlspace/closet/attic/basement.....a can of great stuff or fiberglass batt insulation can seal things up quickly.
If you feel drafts around your windows, consider carefully removing the casing...stuffing insulation in the cracks between the rough opening and the finished window frame.....and seal the casing with caulk to stop air leaks. Don't leave any exterior wall space open.
