Redundant Power Supply
mrbios
I'm looking to replace the 300W redundant power supply from this chassis: http://www.rustybob.ca/albums/userpics/10001/normal_IMG_0828.JPG
We need something that is a higher wattage. Approximate dimensions are 13"x7"x3.5". All the redundant power supplies I've found are nowhere near those dimensions. There also aren't any markings on the case, so I can't look up what some other people have found to be compatible.
If anyone has seen a power supply with those approximate dimensions, that would really help me out. Thanks for the help.
The power supplies themselves should have markings on them that might make finding a replacement easier. Some decent pix wouldn't hurt either.
.bh.
