Reduce DC Fan speed via resistor.....need a bit of help
thirdlegstump
Banned
Feb 12, 2001
8,713
Hey guys, I have an external drive exclosure that's a bit too loud for my tastes.
There's a 12VDC .07A fan in the case and I'd like to reduce it's speed to about half.
What kind of resistor do I need? Can I use something I grabbed from Radio shack?
It's been awhile since I did any electrical study.
Thanks.
Zepper
18,998
The formula is: Edit (sorry, brain fart): I(A)= E(V)/R(ohms). That will tell you the R of the fan. Most 12V fans will run on from 7V to 12V. So you need to get a variable resistor that will allow you to work in that range. (resistor needs to cover the range from 1/2 of fan resistance down to 0 ohms)
.bh.
Almost :beer: time!
sanaka
143
It's: V = IR
As in: Voltage equals Current multiplied by Resistance
NOT: V = I/R !!!!!!!!!!!!!!
Peace
Sanaka
scdill
Thanks.
If the specified .07A is accurate, then the fans DC resistance is about 170 ohms. So:
- A 50 ohm resistor should drop the voltage about 2.7v.
- A 75 ohm resistor should drop the voltage about 3.7v.
- A 100 ohm resistor should drop the voltage about 4.4V.
- A 125 ohm resistor should drop the voltage about 5.0V.
- A 150 ohm resistor should drop the voltage about 5.6V.
Some 12V fans require 7V or more to start.
Mday
18,647
get some low OHM resistors, and wire them up in series till you like it. or get a medium OHM resistor and wire them in parallel ;)
