Redhat Linux 7.3 and Linksys WMP11 Help!
ShinKen
134
Hello all,
Well I have taken the plung and successfully installed Redhat Linux 7.3 as a dual boot to my existing WinXP system. Everything went great, the only problem is that I cannot access my wireless network. I have downloaded the drivers and soon discovered that I would have to compile the files.
When I tried to compile the file with the script it gave me an error about not finding the source files in /usr/src/linux. I looked at my system and saw that my directories were as follows /usr/src/redhat, but all of the directories were empty. Am I correct in thinking that I need to downloard the SRPMS discs and then install (or copy?) the files to these directories?
I am new to this whole linux scene, but I must say that I was impressed by the installation process. It was a breeze. Thanks in advance.
manly
13,274
4,051
No you need to install a regular RPM package named kernel-source. Are you sure the WMP11 is supported under Linux?
Finally, you're right that Red Hat Linux installation is pretty straight-forward. I've seen a lot of reports that both Mandrake, and particularly SuSE have even better installations.
ShinKen
134
I tried to install the RPM, however it was for version 7.2. There was also a RPM for 7.1. I got the info from this site: Wireless Linux Lan, the only difference is that the site is using 7.1. I will try doing some more research to see if there is already a RPM compiled for 7.3. Thanks.
manly
13,274
4,051
Good looking reference site you found there. You should be cool if you install the Red Hat kernel-source RPM package.
Also, if they provided a source RPM package for the drivers, it's really easy to compile a binary RPM package from it.
Finally, if the wlan-ng drivers don't work out for you, give the orinoco_cs drivers a shot. The nice thing about the orinoco_cs drivers is they are part of the standard kernel. Orinoco devices are very popular so if the wlan-ng drivers don't pan out, there is probably a standard way of getting Red Hat to use orinoco_cs drivers without compiling a thing.
Sorry if that sounds a bit confusing, but good luck and LMK if you get stuck.
TonyRic
1,972
RH 7.3 has drivers already compiled for it.
All you should have needed to do is edit the file /etc/pcmcia/wireless.opts and the section containing your card (Quite possibly the Orinoco section) with the WAP key, ESSID and Managed for infrastructure mode or Ad-Hoc for Ad-Hoc mode.
Tony
