I got a Western Digital 100GB hard drive for Christmas. I parttioned it into a number of 25GB partitions and did a fresh install of VVin98.
After the install I got an error when I tried to empty the Recycle Bin. It said the Recycle Bin is the wrong format. I installed all of the Windows Updates and rebooted ar few times. This seemed to fix the problem.
Now, whenever I try to Delete something it will delete and then my Explorer Window will lockup and I need to End Task it.
Also, when I try to Empty the Recycle bin it takes a long fine to empty.
Has anyone else had this problem?
Thanks,
Chris
Thanks,
Chris
