Recording Audio CD with NO BREAK between tracks?
edro
24,326
68
I use NERO, but I don't see where to get rid of the 2 sec delay between tracks.
If you can't do it in Nero, what other apps could I use? Or can you?
Thanks!
thawolfman
11,107
Highlight all of the tracks, right click -> properties and you can edit the pause between tracks.
Fausto
26,521
Get all your tunes cued up and ready to go in Nero, then right click/drag to select all of them and go to "properties". There's an option there to change the amount of silence between tracks. :)
TrueBlueLS
2,931
Disk at once... I remember learning that from helping my friend mass produce his band's CD. The first and second tracks were meshed together and that's how I learned.
