Hi, all.
I just reconfigured my home network and while on the surface things seem to work, I wanted to check to see if I introduced any potential problems.
Scenario: Two rooms opposite ends of the house. Desktop and Comcast cable modem in one room. Smart TV, Fire, Xbox, misc. wireless devices in the other.
Old setup: I originally had a Netgear router in the same office with the cable modem and desktop. Ethernet from cable modem to router and ethernet from router to desktop. Smart TV, Xbox, etc. all using wifi with less-than-stellar performance.
New setup: Per advice from Comcast tech, I ran ethernet cable from office to family room (approx. 125-150') Moved router to family room with TV, etc. Now have ethernet from cable modem to desktop and ethernet from cable modem to router. Previously wifi devices (TV, Xbox) now wired ethernet from router to devices.
Situation: With the desktop no longer plugged into the router, wife can no longer access desktop shared printer (which I expected; purchased wifi printer), nor can laptops see the desktop (also expected).
Desktop now has a 169.xxx IP address but connects to the Internet just fine with very good speed (90-100 meg).
Question: Is this occurring because both the modem and router are trying provide DHCP? I didn't expect the desktop to be in the same network as those devices hooked up to the router, but I didn't expect to get a 169.xxx IP address, either.
Given that other than the 169.xxx IP everything is working correctly, I'm inclined to leave things as-is for now (until I need laptops to access desktop shares in the future).
Did I introduce any security issues by going from the cable modem to the desktop directly vs. having the router in the middle? Software firewalls are on, etc.
I'd really like to keep the TV in particular wired vs. wifi, as the wifi adapter in the TV seems to be really bad.
Any other configurations that could be suggested? I bought Powerline wifi extenders prior to running the new Cat5 across the house, but I haven't used them yet (again, preferring wired when possible).
Thought perhaps of taking the route of logging into both the Comcast modem and the router and checking DHCP settings, etc. but figured I'd check where I stand first before making any changes at that level.
Insight appreciated -- thanks in advance!
--Rudus
--Rudus
