Recommended zoom lenses for action shots?
CuriousMike
3,044
543
Hunter - the lens takes that extra 1/2 second searching for focus.
You want to point your camera ( and focus point ) on your target, half tap the shutter button and have that fucker hit focus instantaneously.
slashbinslashbash
1,945
8
Yes, but this is also contingent upon good body/lens compatibility and using the right AF mode in your body. I am not familiar with Nikon, but in the Canon world you would want to use "AI Servo" AF, which senses motion towards/away from the photographer, and adjusts the focus distance accordingly as the photo is being taken. If a motorcycle is coming towards you at 150mph and you hit the shutter halfway to AF, then click it all the way to snap the shot, your shot will be out of focus if you're on the wrong AF mode.
But yes, focus hunting can be killer. It is more often experienced with 3rd party lenses.
OP, see if you can find, borrow, or rent a 300mm f/4.0. That ought to give you the combo of length, quality, and AF speed that you need, while costing $1350 new. Still pretty pricy, but less than half the amount of a 300/2.8, and better reach than a 70-200/2.8.
Or you can buy a 70-200/2.8 and a 1.4x teleconverter to make it into a 100-280mm f/4.0. Which would give you a little more versatility, although it would lower the image quality and AF a little bit, but still it would kill any consumer-level zoom.
Fenixgoon
32,048
10,822
Picked up a Nikon 35mm/f1.8 for general shooting and a tokina 80-200/f2.8 plus a vivitar 1.4x teleconverter action shots. Hopefully the teleconverter works well, but if not, my previous shots were all at 200mm or less.
Now the hard part- D7000 or D7100? A brand new 7000 is 550, but a refurb 7100 is "only" 700 vs a brand new 7100 at 900-1000
CuriousMike
3,044
543
Depends if the $150 difference is going to hurt.
The extra mega-pixels and newer AF system of the D7100 won't hurt...
(Don't buy new - buy refurb - and look at Cameta as they extend the warranty to a full year)
Fenixgoon
32,048
10,822
went with the 7100. I figure more focus points will help with action shots. That being said, the 7000 wouldn't have been bad either. It's not like no one ever took a decent photo before the latest and greatest camera :)
carlton_fritz
I just picked up a refurb 7100. Love it. Use it mostly with a Tamron 70-200 2.8 VC and for wide shots a Sigma 18-35 1.8 Art.
