Kaido
Completed!
The new setup is as follows:
Cable Modem > pfsense router > 16-port 10/100 switch > wireless router
I turned DHCP off of the wireless router (Linksys WRT54GS), set its IP to 192.168.1.2 (the pfsense router's IP is 192.168.1.1), and turned on WPA-PSK TKIP. The main issue I ran into was that I couldn't get on the router before (I had it set to 192.168.1.30). After changing the IP to 192.168.1.2, I was able to logon.
Original post:
What's the best way to setup a LAN with a WAP? I'm installing a PC router running ClarkConnect tomorrow and I'm going to set my Linksys WRT54GS as a WAP. Should I set the router's DHCP to .100-.150 and the WAP's DHCP to .151-.200? Should the WAP be on a completely different subnet?
edit: or does a WAP not have to have IPs and just act like a switch...never used it as a WAP before.
Original post:
