Recommended file system for a storage hard drive?
N11
309
What is the recommended, most efficient file system to use on a storage disk that is going to be accessed by various operating system both *nix and microsoft windows? Partition to be approximately 20GB in size.
Sunner
Windows - NTFS
Linux - Ext3 since it's well supported, and more than capable enough.
*BSD - The default for your BSD of choice(FFS for OpenBSD, etc).
N11
309
But which efficient file system for a single storage device to be accessed by various OS'? My incline was ext3 but I wasn't sure if windows would be capable of reading/writing to it.
Sunner
Aha, I see what you mean now, dual boot style?, I kinda misread it and thought you meant network access.
Well, for starters Windows can't read jack except for MS's own filesystems, so that rules out all *NIX/Linux filesystems.
FAT32 would be your best bet, Linux has pretty good write support, I've used it quite a bit and never had problems, but still, I wouldn't bet my life on it, I doubt MS handed the Linux developers any docs, so it's at your own risk, and all that.
Need4Speed
5,383
is this a dual boot or is it going to be network storage? If its network storage then ext3 will work since samba will do the filesystem translation
N11
309
Yes this is dual/triple boot. Thanks for the info.
-N11
igiveup
1,066
If its a multi boot platform then Ext3 won't work for you since windows will not be able to access the disk. As far as I can tell you aren't talking about another server. If you are then Need4Speed's suggestion works well (I use Samba).
FAT 16 or 32 for a dual/triple boot system. Take your pick.
mjquilly
1,692
Doesn't FAT16 limit partition size to 2 Gig?
Sunner
No that's 4 GB, under Win9x you're limited to 2GB but under WinNT 4 or 5.x you can go up to 4 GB.
N11
309
So the Windows operating system including 2000 will not read any non-MS file system? Not even reiser?
Nothinman
30,672
Nope. When you dualboot you limit yourself to pretty much FAT. There were some beta quality ext2 filesystem drivers for Windows, but I wouldn't trust them.
