Originally posted by: aigomorla
Originally posted by: Snatchface
I am getting a little disenfranchised with the size and difficulty-of-install with todays air-cooling units and starting to think that it might even be easier to switch to water cooling. The key for me is being able to remove the proc without removing the motherboard from the case and ease of installation. I need a noob unit that has everything I will need included, it doesn't have to be super high-end - just easy to install and reliable.
I am also curious - since these things are so expensive, how future=proof are they? Will I have to throw it out and get another one when the next mobo/socket design comes out? Or will anything I buy follow me through my next several upgrade cycles.
Water is never easier then air. :\ <--- first part where your wrong
The key for me is being able to remove the proc without removing the motherboard from the case and ease of installation. <---- Not possible to mount a waterblock then. Any good, and almost future proof block maker requires you to slide bolts behind the board and load the block via spring retention system. Dont want to remove your board, dont jump to water.
How future proof are they? My ApogeeGT which looks identical in external layout of my old Apogee could fit on S478 S763 <-- err old amd cant remember exact number. S939 LGA775
Swiftech also comes out with addon retention systems to adopt to new processor configs. like AM2 . So yeah their highly future proof until something stronger and more efficent then water is available.
Also using water correctly can extend the life of your processor, silence your overclocked system, and also give you higher overclocks.
ALSO!!! this post belongs in case and cooling section of this forum. Not CPU.
Half of the people who are regulars in this forum is not familar with water. There are better kits available then the swiftech apex, ie petrastechshop elite bundle will pwn that kit. So if your willing to accept the two key things you want, not to happen, i suggest you move this post over to case and cooling where more informed people can help you.
