Recommendations for a 4-way Monitor Stand/rack
Crusty
12,684
I'm in the market for a Quad LCD monitor rack. I've got 4x 22" Widescreen LCD's that I want on the same stand, a 2x2 would be the best setup.
Does anyone have any recommendations for a good brand to be searching for? Or any specific products?
The cheaper the better, but I'm fully expecting to shell out a couple of hundred for it so nothing that's cheap and will break easily.
dawza
921
Any of the quad-monitor KTP series stands should do the trick (edit: or the KTG, if you prefer a grommet-mount):
Chief MFG
I have the KTP225 and it should handle 2x22" just fine; I had it supporting a 24" and a 4:3 20" LCD and there was more than enough space horizontally.
Chief products are heavy-duty and built for industrial/commercial applications. This means that you will not have to worry about monitor droop, rough joints, etc, that are often present with consumer-grade mounts.
You should be able to find significantly lower prices for Chief products at buy.com or on thenerds.net:
thenerds.net link
Crusty
12,684
Chief MFG
thenerds.net link
Thank you :)
I had been looking at a Chief one, but was unsure of whether or not it would support the monitors I had because it was listed on Dell's site as only supporting Dell monitors and I couldn't find their homepage.
Now I have the info I need.
:thumbsup:
