Recommendation for wireless network card - PCI
briddle
I have a generic comp geek network card, but when tha pc goes to screen saver or after a couple of hours of inactivity, the connection is lost and you have to reboot.
I need a good card to stay up all the time. I have a b router - 3com.
I have a netgear card that stays up all the time, but does not get a very fast connection. I was going to try one of the two linksys cards at officemax on sale. We do not have anything but an officemax B&M locally.
Help please??
Check if the power saving in your current card is Enable (look at the drivers properties).
I it is Enable, disable it and it might solve the problem.
Make sure that the SSID in your Router is On, as well.
:sun:
