anandtechreader
Hi, I am looking for a silent or almost silent case to build a high-end workstation with i9-9900K and 1-2 RTX2080Ti. Between the Cosmos C700M and SL600M, which is better? Any other suggestions?
Two 2080 will make a lot of heat. Silent cases tend to perform worse in thermals. Are you sure you want this, for a workstation?
The SL600M won "best thermals" from GamersNexus (a respectable reviewer), and while i wouldnt touch a CM product with a cattle prod (i would go Fractal Designs instead), the SL is probably a good choice.
Check https://www.google.com/url?q=https://www.gamersnexus.net/guides/3397-best-and-worst-pc-cases-of-2018
And the video:
If going SLI I would definitely get a full size tower. FD XL R2 is what I use for my main windows box.
Yes, the R series is numbered consecutively, do the R2 is older. Afaik the R4 was the peak of the series, i myself worked with a R3 midtower and it is phenomenal, very quiet too.Thanks. I am a bit confused about FD's naming convention. Is R2 older than R6? I also cannot find full tower or mega tower in the newer? R6 series.
I can't disagree more. A fully custom water loop is still louder than air. You still have just as many or more fans than in an air setup and you also have water pumps. Even the quietest water pumps are still louder than any fan I use in my systems (including GPU fan). What water does get you is the ability to overclock more while keeping the noise levels down (air hits a limit much ooner and more so if you are going for silence).I disagree, you can do silence with water cooling, it just isn't cheap and temps will be slightly higher than if you were running fans at full temps. Have one rad for the gpu's and one for the cpu. Using a massive corsair 900D and a custom loop, you can get silence + water cooling, it's just expensive as hell.
