Originally posted by: dxpaap
thx everyone, good to know about setup menu.
skyking, I've been pondering your unix suggestion.
I have a few old 200 to 400 mhz boxes collecting dust in the basement. Do you think turning them into stripped down unix/linix firewall boxes is relativily easy to do. I've worked with SCO/unix over 5 years ago (so not clueless but defenatly very rusty).
My concern is ease of configuring it as a firewall - I don't have enough free time to spend huge amout of hours fiddling & tweeking. I would like to get it working, put it in a corner and forget about it - is that a reasonable expectation ??
thanks for any comments
You have a leg up if you have any experience at all. It took an evening to get the firewall/router up and serving my network for basic needs, and I have only messed around forwarding gaming and other ports through to the proper boxes.
A hard disk failure will shut you down, but I use small ,<2 gig drives, and ghost a backup drive after I get it the way I want it. If a drive craps, I can get it going in a few minutes again.
As to the "set it and forget it" aspect, the major difference operationally is the reboot. ISP's router's crap out, drop connections all too often. Sometimes they come back, other times you reboot the modem, and it comes back. Sometimes it takes a reboot of the router also, and you can't just pull the plug on a running OS without some possible consequences. You would need to ssh into the computer, su to toor or root, and reboot.
Same thing applies with power outages, a hardware device will come back up without consequence, unless spiked by a power surge.
A running OS and filesystem can have some issues with that, depending if it was in the middle of some write operation.
