Recommendation for quiet Slot A HSF that uses a 60mm fan?
Tonec
1,505
Hmmm the stock hsf is usually the quietest one you can buy, maybe the flk32 with a panaflo would work.
Losty
1,136
loud? the stock hsf is usually the taisol...depending on which cpu you got...i think it's about 32db according to taisol.com...
Tonec
1,505
Taisol fans are rated at 21cfm, 37 dbl but I don't think its anywhere near that load, could be that it has a low hum to it instead of the high pitched whine of many case fans.
