W whistleclient Platinum Member Apr 22, 2001 2,700 1 71 Jun 3, 2004 #1 I was wondering if anyone has a suggestion for a powered FM antenna that they've had success with? I'm getting crappy reception here...
C Cashmoney995 Senior member Jul 12, 2002 695 0 0 Jun 4, 2004 #3 You cant power your antenna. Antenna's pick up information, they dont amplify it. You can try mounting an antenna near a window and then wiring it to your receiver, there are several kits out there which do that.
W whistleclient Platinum Member Apr 22, 2001 2,700 1 71 Jun 4, 2004 #4 can't FM signals be amplified and interference reduced? are you just arguing semantics?
