I have a couple in each of my cases. I can hear them, but I wouldn't call them loud. But I like white noise, so... They are 3 pin and come with an adapter if you need them.
i have 5 of those svc fans in my computer. they are moderately loud, but not in an annoying high pitched way like some delta fans are.
usually i run them at 7v though, because they are dead silent at that voltage...but the LEDs tend to dim when you lower the voltage..
Yeah, for a while I had the LED fans in one case hooked up to the "fan only" header on my Antec TruePower 430 and the LEDs were very dim, which defeated the purpose, so I stopped using the fan only header.
