Recommendation for Blinds
KillyKillall
I'm going to be installing blinds in my whole house (actually, I think I met let someone else do it this time). Anyway, I'm just curious if any of you have had great/horrible experiences with any certain companies in that area. I'm looking for someone in the Tucson area. I know 3 Day Blinds is here as well as Home Depot. Any other suggestions or experiences?
Thank you in advance.
save money and do it yourself
if you have standard window sizes, buy the pre-cut
if not, you'll have to buy the expensive blinds and have them cut
either way, installation is easy
you need a tape measure, a pencil, a drill and a screwdriver (and a chair/ladder to stand on)
I've done the installation multiple times on various houses, but trying to save some time. The new house I'm in has been fishbowl style now for a few months becasue I haven't been able to find the time. I'm scared if I buy it all to do myself, it won't get done for a few more months.
I figured the installation would only tack on about another $200 or about that. Saves me the headache for now.
Also, I'm looking to get most likely wood blinds or something a little nicer than what they usually sell pre-cut at home depot and what not.
Well it depends on the number of people you have, usually you can start at $1/$2... then just double them at a set interval (either number of hands played, or a certain time).
Did we start playing hold'm in here?
