Recommendation for a Socket A Motherboard
I need to replace my current ABIT KR7A-RAID. Even though I've replaced the battery to store BIOS settings, it still won't hold them. Any suggestions for a board that holds my Socket A XP 1700+ CPU? or maybe I should upgrade to a newer CPU, PSU too?
DFI makes some solid Socket A boards. I currently have the NFII 400-AL and it suits me just fine (not good for overclocking, but I don't overclock). However, you can get yourself a 64-bit sempron for as little as $65, and pick up a motherboard for $40. It'll give you a nice boost for $100.
good idea
If I've ever looked up that particular MB in the past, I can't recall if it's a DDR or pre-DDR board. Assuming DDR, the least expensive that Newegg has from a brand I'd feel some trust toward is an Asrock with a Via KT-400 chip set:
http://www.newegg.com/Product/Product.asp?Item=N82E16813157072
Biostar and Foxconn both had been making "two-way" socket A MB's that have both 168-pin slots and 184-pin slots for either of the once-popular RAM types, but I didn't see any of those on my first pass through Newegg.
Just a shot, but if your board is still under warranty you could RMA the board back to Abit. I've done a few RMA's with them and it's pretty easy to do. Good luck.
Originally posted by: Lonyo
Abit NF7
The NF7-S v2.0 was the best Nforce2 Ultra board out there without a doubt.
The NF7-S2's havent been so great.
If you can find a cheap deal on an old NF7-S v2.0, go for one.
Thanks a lot for the suggestions! I'm going to ponder it a couple days and probably buy early next week.
Thanks again!
What kind of stupid fvckin question is that in your sig?
What's your answer?
If you just want a replacement motherboard, one can be had for as little as $29.49. I don't suggest spending much more than that for the sake of an Athlon XP 1700+.
However, you could upgrade your motherboard, CPU and RAM without too much trouble.
motherboard ($64) <--- good overclocking board
CPU ($65)
RAM ($47)
total upgrade price: $176
Then, you could sell your Athlon XP & PC2100 RAM. I bet you'd get at least $30 for each, bringing the net cost of upgrading to ~$115.
So, there you have it. ~$115 for a Sempron 64 2600+ upgrade or $30 to fix your Athlon XP 1700+ setup.
Try to grab a used Lanparty NFII UltraB from the forums (or get a new one if you can find one).
The Abit NF7-s is also a nice board.
~new
