recommendation for a PCI DirectX 9.0, please
dxpaap
looking for a card that support s Direct x9.0 on a P4 based system with only PCI bus - looking to play DoomIII & Macks Pain II
thanks in advance
thanks in advance
Um you could try ATI 8500, 9000, or 9100, or perhaps the 9200. The 9200se has a pci version, but I would not recommend it. I don't know if you can find a pci version of the Ti4200, I would strongly recommend that. Otherwise there is the GF4mx and fx5200 with pci versions, both of which aren't that great. Anyhow, I probably would not recommend running doom 3 on a pci card, although you might be able to run it at the lowest settings. Max Payne 2 (I assume you mean this game) I've never played, but it will probably run fairly well with the cards above.
AFAIK those cards (mentioned above minus the FX5200, if there is a PCI version of it) don't have DX9 hardware support & even if there are PCI based DX9 cards on the market, it wouldn't be powerful enough to even handle DX9 from the getgo.
thanks in advance
As AnonymouseUser said, there is no PCI graphics card that can run these games.
Also, you probably have an emachines POS machine with an original P4 chip (the slow >2 Ghz series... pre-Northwood), so your CPU probably isn't great either. Very few machines sold within the last five years lack an AGP port.
The (only) "DX9" card (albeit with a partial featureset) is the underperforming GeForce FX 5200 series.
The best card you can get for PCI is a Radeon 8500/9100, but they are still both DX8 cards and are considerably slower than even middle-end AGP cards.
Originally posted by: JBT
Originally posted by: Mloot
PCI card review
For now, the best PCI cards are the Radeon 9100 PCI and the FX 5600 PCI and 5700LE PCI.
Those 3 are all 5200's if you look at the chipset. They do atleast have a 128bit memory interface though. so it might not be half bad to go with the 5600 one as all the 5700 has is another 128MB of memory which is a waste.
I have to disagree. The 9100 is definitely NOT a 5200. And the 5600 and 5700 are also NOT 5200's. I've actually owned the 5600 PCI and I can tell you that it has a 5600 chipset, and the 5700LE PCI is a brand new PCI card with a 5700 chipset. The part on the web site that shows that it has a 5200 chipset is really just a typo.
Originally posted by: jiffylube1024
Originally posted by: Schadenfroh
Originally posted by: AnonymouseUser
There is no PCI graphics card that can run these games.
sure one can
No, it can't
Nvidia has provided me with a latest generation Quadro FX 600 card, derived from the company's GeForce FX 5200
The FX600 is just an FX5200 with 256MB of DDR on a 128-bit bus (7.8GB/s bandwidth) and tuned for high-end OpenGL apps.
it was a joke...... i would have never suggested a $600 card for gaming.....
Obviously 😛. Still wouldn't work though. If it was a PCI FX5900 or something than maybe it would be a tad different (but still a total waste of money).
It's pretty clear that there's only one true solution here: buy a new system with AGP.
Sigh, all those suckers who buy Dells thinking they are getting a "great deal" . You cannot get a great deal on a Dell, even if it is a bit cheaper than the norm, it will always be a Dell; a far cry from an 'Enthusiast's' system...
PCI card review
Yeah sorry I obviously didn't mean the 9100.... I was just going by what the store said they were... and wouldn't be suprised if they were 5200 chipsets in the least.
You can find a P4 platform mobo w/ an AGP slot for not a lot of Bank. Then get yourself at least an 9600 Pro/XT if you want to play those games decently. We are running DoomIII decently with a 9600XT. Any PCI VidCard is going to be Bus-limited, no matter which one you use.
well, thanks for the helpfull advice as usual - I mean that 🙂
Unfortunatly, this was a $300 deal from Dell Business site - mentioned on the "hot deal" fourm last month. For the money not bad, its a homework system for my grade school son. Was building him a better one, but ran into technical problems and school begining - so resorted to doing something fast.
It has onboard video but I figured, I could slap in a DX9 video card - but was shocked to findout the Dell didn't have an AGP bus !!! Silly me for not noticing before ordering.
anyway, shame on me - thanks for the discussion
Look inside it and verify that the slot is not there. Dell has been known to claim that a system doesn't have AGP, when in fact, the board does.
That is highly unlikely. Their basic business machines rarely do, and even some mid-range machines are lacking an AGP slot.
