Recommendation for a luddite
MiataNC
2,215
I have been taking a lot of road trips and traveling a lot more in general in the last year. I would like to record my trips.
I am looking for a decent camera that is idiot proof, takes great pics, can be mounted on a tri-pod with a timer (for solo trips), and is small and compact (space on a bike is limited). I'd like to stay in the $400 range if possible.
The Canon G9 or SD1100 look interesting, but as a clueless newb, I suspect there are better choices out there.
So what would the gurus of Anandtech recommend?
ElFenix
102,402
8,574
you'll want a wider angle lens than the G9 or SD1100 provide. i'd say look for one with a 28 mm or shorter wide angle. the G9 isn't the most compact camera around, either.
Jawo
4,125
The G9 is arguably one of the best non-dSLR cameras on the market today. It has incredible flexability, RAW capabilities, and most manual features. I have a friend who has produced incredible panoramics with it.
alfa147x
29,307
The Guru has arrived J\k ;)
I would say the G9 if you wanted a DSLR but had no room, what's wrong with learning a camera?
we all went from clueless newb to clueless
