Please recommend Possible upgrades to get maximum juice of this system.
Gonna purchase in USA (only via online and can't do in-store purchase) within next 2 days.
Purpose:
Will be running 2-3 OS in VMWARE workstation, Cisco UCS Simulator, GNS3 software ( not simultaneously though)
[For those who do not know GNS3 - it is a simulator for Cisco Routers used for doing practice labs for Cisco Networking Examination at Expert level.
Running 2-3 instances of router on GNS3 / Dynamips/Dynagen demands CPU cycles 'horsepower' ]
If you think it is not worth spending money on upgrading this please recommend what is the best that I can do with this sys?
Budget
Max $150-$200
My current Hardware:
CPU: AMD Phenom II X2 550 - 3.1GHz. (done coreunlocker - running as X3 as X4 is unstable and gives boot issues)
RAM: 4GB (DRAM Frequency-666.7 Mhz).
Mobo: ASUS M4A88T-M LE ( 880G chipset= HD4250). with PCI e 2.0
PSU: seasonic s12ii 520
GPU: ATI/AMD Radeon HD 7770/R7 250X
HDD : 128GB SSD (kingston) + 2 * 1TB WD blue drives
Question:
1. Should I upgrade max RAM supported to 8GB or not to bother with it and upgrade the CPU, MOBO & RAM?
2. What is the best possible CPU ( within the budget) that I can go for , in this mobo?
I request you recommendation.
Purpose:
Budget
Max $150-$200
Question:
 Facebook
Facebook Twitter
Twitter
