Recommend splitting device to power 5+ case fans - No fan controllers!
garetjax
82
Looking for alternative devices to power 5+ case fans from a single splitter powered by molex connectors. I am not looking for a fan controller though! =)
SunbeamTech has their Multi-Fan Power Port (MFPP), but I'd like to know what else is out there that competes against it.
Thanks!
Lightflash
274
Check out FrozenCPU.com and look at fan ports. I think they have just about every option for connecting fans to a board.
Is there any reason you do not want a fan controller? Just wondering the reason.
garetjax
82
I really dont want to mess with a bunch of wiring inside the chassis as I'm pretty fastidious when it comes to clean wiring and cable runs. Also, the fans that I am using, when running at full RPM, barely push above ~35dBA so controlling them really wouldn't make a difference.
I just wanted something where I could connect them all into one device and not be bothered with more cabling is all. The Sunbeam device looks like the ticket, but wanted to know what else was available.
aigomorla
21,086
3,589
http://www.jab-tech.com/BitsPower-X-Station-PowerExtension-I-UV-BP-XPSP1M-UV-pr-4261.html
Bitspower power station.
however u might need to put Y's if u require more headers.
Or if they have a molex head, you can plug them into that unit directly.
Want something even more simple? However u still need a header going out to a molex header..
ModMyToys:
http://www.performance-pcs.com/cata...e=product_info&cPath=60_392&products_id=30359
aigomorla
21,086
3,589
refresh... i made edits.
