Recommend silent equipment? 400w+ PSU & 60mm fans
Kaido
Feb 14, 2004
49,666
6,046
I need a silent 400w+ ATX PSU and silent or quiet 60mm fans for my next project. Any recommendations?
Zap
22,377
Good luck on that. I could never find anything smaller than 80mm that was worth a damn for quiet operation. The quiet ones pretty much move almost no air. One workaround that I've done is to use a quiet 80mm fan (I used an NMB) and duct it. I tore apart a 60x10mm fan so that I just had the outer part (to attach to the 60mm fan mount), then made a custom and curved duct to the 80mm fan using aluminum flashing and aluminum tape. It was really quiet and moved decent air.
