recommend me the best sound card for my computer speakers
leeland
3,659
basically what the title says...what card gives the best performance for these speakers ?
Thanks
Leeland
leeland
3,659
Originally posted by: Nohr
The Audigy2 ZS is the popular card at the moment.
currently I am running a sound blaster platinum 5.1 (which has no optical out) does this card have an optical out which I would be able to use on the speakers ? It has been so long since I bought a sound card I can't even remember when I bought the card I ahve now :)
Thanks Leeland
Nohr
7,302
32
101
www.flickr.com
Thanks Leeland
Yes it does have Digital 5.1 out. Specs and whatnot are here: $88 at Newegg
Tostada
The only two cards I see worth considering these days are the $40 Santa Cruz and the $88 Audigy 2 ZS. Everything else is a complete waste of money compared to those.
Of course, you'd have to pick the Audigy if you need the digital 5.1 out.
txxxx
1,700
M-Audio Revolution?
EngenZerO
5,099
agreed... this soundcard is pretty sweet. its way better then my regular audigy in my older box.
imported_Kyzar1
22
Would there be any significant reasons to go with the Audigy 2 ZS Platinum Pro over the regular Audigy 2 ZS for the average user? The external I/O box does seem cool, but I'm not sure that I would use it enough to justify the extra money.
Kyzar1
Kaido
Feb 14, 2004
51,625
7,267
Creative Labs Audigy2 ZS or the M-Audio Revolution 7.1 are both good cards. Both are PCI, both have 7.1 channels, and both have digital output.
I have an Audigy2 ZS. The drivers and software included are good. They even include a DVD-audio player. Their software can be a bit slow sometimes, like when you're adjusting settings, but it's good stuff.
Make sure you get a digital cable for your z-680s. Oh yeah, the Audigy2 is THX certified, as are the Logitech z-680s.
Tostada
Is there any reason someone would pay $93 for the M-Audio when the Audigy 2 ZX is $88? And don't say the 107dB SNR vs. 106dB SNR. :)
high
Banned
Sep 14, 2003
1,431
Kyzar1
you do realize that the audigy and audigy2 are basically an identical card, but the a2 has 7.1 and optical out?
ponyo
19,688
2,811
If you get Audigy 2, use the analog connection instead of coaxial. Analog should sound better with your Z680 and will let you use 5.1 on everything. Use coaxial out only if your card has crappy DAC.
If I had the money I would go with Audigy 2 ZS.
txxxx
1,700
Everything else is not a complete waste of money, thats my point. There are alternatives to creative haters, and the Santa Cruz AD/DA units dont really compare to creatives nowadays.
imported_Kyzar1
22
Kyzar1
Read it again. I was wondering if there are significant benefits to buying the Platinum Pro version. I never mentioned the original Audigy card.:D
Kyzar1
CJP
512
Does the digital out on the Audigy 2 ZS do 5.1 (3d Sound) for games as well as DVD's?
ponyo
19,688
2,811
No. Just for movies. No point of using digital with Audigy 2 and Z680 when analog sounds better.
CJP
512
Can you have the analog and digital hooked up at once so it uses analog for games and digital for movies?
Lazy8s
1,503
no two diff connections.
btw I have klipsch 4.1 on an audigy 2 and it sounds better than my $1000 sterio system I got for my T.V. so I bought the klipsch digital decoder and hooked up a set to my T.V. and it would take a lot of convincing to go to anything else. It may be the speakers but that audigy2 is so much nicer than my old 5.1 card.
