Periods and commas are your friend.the icemat siberia's are some good headset one thing bad mic is ok not great but ok than there is the dsp-500 what i have great headset i love than there is the pc-165's by Sennheiser also steelpad makes some 5h's i heard about.
Originally posted by: w00t
lol i was lazzy i will just give you links.
http://www.newegg.com/Product/Product.asp?Item=N82E16836508101
http://www.newegg.com/Product/Product.asp?Item=N82E16826106012
http://www.newegg.com/Product/Product.asp?Item=N82E16826106381
<a target=_blank class=ftalternatingbarlinklarge href="https://www.steelpad.com/default.asp">https://www.steelpad.com/default.asp</a>
these would all be good choices if I were you i would go with the icemat siberias.
Originally posted by: wafflesandsyrup
@#%$!! do a seach, youll get plenty of ideas.
Headset has a microphone, headphone doesn't. Of course, it's easy to add a clip-on mic to a headphone.whats the difference between a Headset and a Headphone ?????????????
Originally posted by: YOyoYOhowsDAjello
Originally posted by: Excelsior
Senn hd280s, or HD-497s off amazon.
Originally posted by: Ricemarine
sennheisers are from japan? lol. I thought they were from germany!
headsets.
-Sennheiser PC150 🙂
-Logitech Gaming ones that are behind the head that I don't know about much 🙂
headphones
-Grado SR-60's (open cans)
-Sennheiser HD280's (closed cans)
