Recommend me a USB hub with built-in card reader
fbrdphreak
17,555
So the title pretty much says it all. Need a powered USB hub, minimum four ports, with built-in card reader that supports all latest formats. I can compromise somewhat on the formats, but it must support CF and xD.
I have an IOGear one that I like, but it doesn't support xD. In the end I may have to compromise on it altogether, but for now I thought I would see if anyone had come across something like this. Thanks!
John
Moderator Emeritus<br>Elite Member
searching.......but I can't find anything. The closest was 3 USB bus powered with xD support. :(
However if I were you I would just get this to plug in the front of your IOGear and call it a day. It would also come in handy for road trips when you have access to a USB port. :)
fbrdphreak
17,555
Thanks for the effort John. I did think of getting another IOGear and using one of those stick-xD adapters. I saw the 3-port one you linked before your edit, I'll probably lean towards the IOGear at this point. Thanks for your help!
